UE22H5600AK Recommended Bluetooth adapter
(Topic created on: 28-11-2017 03:09 PM)
Jandki
Hi, can anyone recommend a Bluetooth adapter for my UE22H5600AK set?
I assume that as Bluetooth isn’t built in the only way for me to connect my Bose headphones is either a very long lead or to fit an external adapter.
Suggestions / recommendations would be welcome.
thanks
1 REPLY 1
Mystery1
No, but when you find out, can you check if it's compatible with the ue32t5300
Why can't Samsung just recommend one!
