TV Feet adjustable on TU7100?
(Topic created on: 23-11-2020 12:41 PM)
Grapenutz
Hi
Does anyone know if you can adjust the feet on the TU7100 TV? Can you move them closer together towards the middle or can you replace the feet with a central stand (purchased separately)?
Thanks!
1 REPLY 1
Shazzkid
Troubleshooter
The feet are not adjustable. But you can buy a stand or wall mount. They both attach at the back of the TV via the VESA mounts.
