Go to solution Solved
The Frame 43'' QE43LS03AAUXXH Vs QE43LS03AAUXXU
(Topic created on: 24-04-2022 08:12 PM)
About35
Dear Experts,
I've ordered a The Frame 43'' model QE43LS03AAUXXU (ending with 'U'),
but, I've received a slightly different model: QE43LS03AAUXXH (ending with 'H').
What are the differences between QE43LS03AAUXXU and QE43LS03AAUXXH please?
Thank you, Regards,
Claudio
JAMES4578
Samsung Members Star ★★
@About35  The last  two letters relate to the country code and XU is used for  the Uk, it seems a few European countries use XH.  Some information here https://en.tab-tv.com
1 REPLY 1
JAMES4578
