Subtitles encoding
(Topic created on: 10-03-2021 02:08 PM)
Jay001
Hi guys, that’s my Samsung TV UE43TU7100KXXU. I am having issues with the subtitles on a USB stick. They are a separate fail and the TV detects them, but they come out as weird signs and like the language they are meant to be. On Sony TVs there is an option where you can select the encoding of the subs/UTF-8 for example/. How can you do that on this TV? And Yes I already selected the relevant language from Accessibility/Subtitles Settings/Primary and Secondary Language menu. Thank you.
2 REPLIES 2
Funkztadelic
Check the character encoding settings on TV.
Kremena Velkova
Hi, I have the same problem. Would you explain to me how to chech the character encoding settings on TV.
Thank you!
