Go to solution Solved
Smart view missing feature
(Topic created on: 16-08-2025 07:10 AM)
Wingskapoor
Hi, need help. I have s22 and s21. With smart view feature I wad able to cast my tv to my phone. Now I dont see that option in the smart view.
My s9 has old version of smart view ( 6 version). It works fine.
But new version of smart view doest show that feature.
Other devices to tv. Pls help
johnz237
Samsung Members Star ★
Hi! Welcome to the samsung members community!
SamMobile- have a read https://share.google/PBOAGomWn7tSmPfUT
*assuming I read what your question correctly. Cast tv to you phone
3 REPLIES 3
johnz237
bilbob2002
Pioneer
I found i had this issue. I opened a video in gallery then pressed 3 dots in the right corner and pressed open in video player. Once playing then press smart view and the tv should appear in the options box and once you have selected it it should come up next time without all the messing about. Hope this works for you too.
Wingskapoor
Thanks Guys, I found the option.
