29-06-2020 03:03 PM - last edited 29-06-2020 03:09 PM
- Mute
- Highlight
Hello,
I am trying to connect my desktop computer via an HDMI cable to my new Sumsung Smart TV (7 series, TU7100 model).
It says "No Signal" on the TV screen on both HDMI inputs.
Details and stuff I tried to fix it/isolate the probelm:
1. The computer recognizes the TV. It recognizes it is a Samsung TV and the resolution.
2. The computer works with a different TV (Panasonic) via the HDMI cable.
3. A different HDMI cable didn't help.
4. I tried to connect a different computer (this time a laptop), didn't work as well.
5. Tried to disconnect the TV from the power (for >10 minutes), then plugged it back in and tried to connect everything in different order each time.
6. The HDMI input works when a digital television adapter (local channels) connected to it.
7. I updated the TV software/firmware through the settings page.
8. Both of my computer run Windows 10. My desktop is using a GeForce 1050 graphics card and my laptop is using a AMD Radeon graphics card.
All of the above makes me think it some software problem in the TV. The HDMI itself works, including the cable, and both computers work with another (Panasonic) TV.
However I couldn't solve it.
It is extremely frustrating as this is my main use case for the TV and it is a newly bought TV set which I received today.
Thanks a lot,
Michael.
17-08-2020 07:43 PM
- Mute
- Highlight
I have the same *****!!!
27-08-2020 06:47 PM
- Mute
- Highlight
have you tried to disable the "input settings plus" in
settings > general > external device manager
03-10-2020 06:23 PM
- Mute
- Highlight
I have the same problem that just started. Was working fine. Any solutions?
25-10-2020 09:25 PM
- Mute
- Highlight
I spent a hour trying to get my Asus laptop (Nvidia GTX 1060) to connect to my 2018 Samsung Q9 using HDMI.
The Laptop screen went black and TV cycled between black screen and "no input".
Traced it to the HDMI port on the Samsung smarthub being set to "HDMI UHD Color" enabled. You can enable/disable it
on each port "Settings -> General -> External Device Manager -> HDMI UHD Color".
(I think this is the same as vaness described above).
I did try wireless casting to the screen and it works ok for playing video however for gaming the response is not good enough - unless you have really fast wi-fi maybe.
With the correct setting the laptop displays fine at 3840 x 2160p.
09-11-2020 10:54 AM
- Mute
- Highlight
I have the same problem did you find a fix?
20-03-2021 06:22 PM
- Mute
- Highlight
Had this issue with Input Plus which caused the loss of signal. Seems like the TV keeps the SDR settings on that HDMI port, and restarting my PC or TV won’t help. Disconnecting and reconnecting the HDMI cable helps with the connection to be re-detected as HDR. Hope this helps.
30-12-2024 03:52 PM
- Mute
- Highlight
Same problem with q7. connects then disconnects... need a doctorate to handle samsung products. they never work flawlesly and are full of bugs and underdeveloped. Always problems with samsung and this is my last product from this crapy company.
Even the phone S23 ultra still cant handle fingerprints and we are in 2024...
