13-12-2019 06:54 PM
Hi,
I've had the smart hub update problem for 2 days: "smarthub is being updated please try again later". I've seen that lots of people have had the same problem and it's been suggested Samsung are deliberately blocking some customers to force them to buy new TVs.
Is there a fix, or is it actually a scam by Samsung?
My model is UE32F4500 and my software is 2127.
Some people have said they fixed the problem by doing something with the physical on/off button on the set, but my model doesn't have a button like that.
Advice please.
27-02-2021 06:01 PM
That does not work for me. I've got tons of problems with my UN630D Samsung TV. Smart hub doesn't work. No apps. No nflx, no amzn. no sleep timer. no control over volume. no control over changing channels. remote management grayed out. samsung account grayed out. can't load apps. went thru hours and hours with samsung tech support on phone and they say try this, try that, nothing sticks or causes other problems. tv is worthless now. searching this community and others, it seems these problems are persistent over many years and many models. Even the samsung techs responding to messages here give up. Their escalation process speaks volumes about their customer service, their products, and their quality. What do I do now?
10-05-2024 08:43 AM
Thanks "StillNotARobot". That worked for my Samsung UE40F7000 TV
Go to Menu > Smart Features > Reset Smart Hub.
It got stuck doing updates a week or 2 ago.
I was using a Firestick but the Samsung's Amazon TV App on the TV did not show the new Amazon Adverts while the Firestick did, so glad to get the TV Smart features back. Remains to be seen if the adverts start appearing....
09-01-2025 11:10 AM
That worked for me. Thanks
21-03-2025 05:13 PM
WTF...simple thing as connecting a computer to an HDMI port and the TV errors out?????
21-03-2025
05:15 PM
- last edited
21-03-2025
05:50 PM
by
ChrisB_
I have to use my old remote to select SOURCE and it works....
