Samsung UN32EH4003 shows blinking blank screen when powered on
(Topic created on: 04-05-2020 06:06 PM)
NYGiantsFan
My Samsung TV (un32eh4003f) shows a black screen that blinks when powered on. There is no picture or sound and the buttons don't seem to be doing anything either. Does anybody know if the TV is salvagable?
4 REPLIES 4
CarloL
Hotshot
Hey @NYGiantsFan! Is the TV damaged in any way? Have you already tried unplugging it from the wall socket and plugging it back in again? Where did you puchase it from and where are you located?
NYGiantsFan
Thank you for the response @CarloL. The TV was working fine, powered off by itself for a couple minutes, and then returned to normal for about 30 minutes. Then the screen went blank and began to start blinking.
There doesn't appear to be any damage.
It stops when the power supply is removed but continues when plugged back in. I believe it was purchased from Best Buy and I am in New Jersey.
Thanks again for your reply!
CarloL
Hotshot
Hey! Right, it would be best to get in touch with the Samsung US technical support about this then, they can be reached here: https://www.samsung.com/us/support/
Barrys_Qled
Pioneer
I have a blinking black screen issue too.
I posted a video on YouTube link below...
https://youtu.be/lYMzkr8Xj3s
My issue happens after about 4hrs of play on my ps4, after this my tv does not recognize anything in source. I believe this is an overheating issue. My TV is just over a year old. My tv is Q9FN 55in.
