Samsung tv glitches
(Topic created on: 19-06-2022 05:34 PM)
Hi,
My Samsung tv is turning on at random times of the day. We have 2, and this one is the one that is turning on randomly. I swapping my remotes with the other tv but it has the exact same problem still (the tv has the problem). I checked smartthings and I don't have anything triggering the tv
Please try and find a solution
Also as a side note, both of my samsung tvs are running very slow in terms of navigating the UI. If I press a button after turning on the tv, it takes about 15 seconds to respond, and afterwards it still takes 5 seconds to respond to each button press, which is really frustrating.
3 REPLIES 3
Pakkos
i thika
Pakkos
what
ishollywood onmay
antikythera
Black Belt
It's probably looking for firmware updates, try turning off automatic updates and see if that stops it. You can get any updates from the website anyway and load them in manually via USB stick if needed
