Samsung qn95b 85" TV "Different issue"
(Topic created on: 23-04-2023 08:42 AM)
Jave47k
Hi all,
From LG oled to Samsung neo.
Samsung got a lot to improve.
Never had so much issue with TV before like i have with the Samsung. 🙄
1
They qn95b uses one connect box and som times TV won't start up had to plugg in and out of wallplugg to start the TV.
This issue above was fixed by "admin" settings from Samsung.
2
Remote control for qn95b omg what happend here? It takes ages to get in to settings meny.
Remote controller reply is really bad when you pressing down it takes ages to get into meny or different tasks.  Maby something wrong with "IR" on TV or Connect box.
I'm on my 3rd controller that Samsung did send out to test same issue still.
3
Quality pictures settings is really poor you need to tweak alot to get decent picture quality. When you go from Oled to qled you notice what I mean.
4
Calibration for picture mode "fast" works but professional Calibration mode is broken won't work I tested this with fold3, fold4, Samsung 22 ultra, S23. Talked to Samsung support about this still NO respons sadly.
Do somebody have issue above?
#neo qled
#QN95B
#Samsung qn95b
2 REPLIES 2
underkiller
1."This issue above was fixed by "admin" settings from Samsung"
Can you explain what "Admin" settings is`?
Adriano expexial
Seriam capaz de me informar como corrigiram esse problema? Falam na configuração do "admin" e não consigo perceber como corrigir isso.
Fico a aguardar resposta l. Obrigado
