19-02-2026 09:00 PM
hi 2 days ago I turn off the tv by the physic button down my tv QLED42 since that moment my remote control doesn’t work. When I remove battery and I re-put inside open in automatic Netflix, and leds on smart remote continue to flash fast never stop also if I press reset button combination. I try everything that I found online, remove battery and press 60 second the power botton or press back and play bottons together for pairing…nothing work.
I try to eliminate the app and I try to eliminate cache. Also this don’t work.
help me please 😞
19-02-2026 09:52 PM
Hi @giamma95 Welcome to the Samsung community
check that the Remote is sending an infrared signal. point the remote at your phones camera and press/hold the power Button on the Remote. Take a look at the camera's screen, if the remote is sending an IR signal you will see a coloured light coming from the remote control.
After reinserting batteries (or new ones) press the power Button for 8 seconds. https://www.samsung.com/my/support/tv-audio-video/samsung-tv-remote-control-is-not-working/?srsltid=...
you can also try rebooting the Tv for a minute and try pairing again. https://www.samsung.com/latin_en/support/tv-audio-video/how-to-troubleshoot-a-remote-control-that-is...
