01-02-2021 08:47 PM
Hi, my NU8000 don't decode HD audio. I have it connected using ARC HDMI with my home cinema system, but when I play BluRay from my Xbox Seris X (no sound) or movies from USB (audio not supported). Is that true that this model has no DTS or DD compatibility and blocks HD audio completely?
01-02-2021 09:03 PM
02-02-2021 02:28 PM
Well, actually this TV plays all my AVI and MKV movies from USB perfectly fine as long the sound isn't DTS. So basically if I buy a soundbar and connect it to my TV using HMID ARC or optical cable, it won't decode DTS anyway? I won't have a sound from my Bluray. The only option is to connect my Xbox to the sound decoder (soundbar or AV receiver) and then to TV?
02-02-2021 02:37 PM
