Multi view not working when I try to play Xbox and have YouTube at the same time. Qe55 q80t
(Topic created on: 09-12-2020 06:55 PM)
Bengie11
So basically when I try to have Xbox running on the left side of the screen and YouTube running on the right, the left side comes up with "this content is not available in multi view" I believe Samsung says that you can have a hdmi plugged in and run it on the left side. Not sure why this isn't working please help. The tv is a 2020 QE55Q80TATXXU
8 REPLIES 8
Harrisoncurr95
Having the same issue, you managed to find a solution?
Bengie11
Not yet, I’m hoping they fix it because I literally wouldn’t use multi view for any other reason. Seems like a useless feature at the momen
Harrisoncurr95
I tried it with my Xbox one and it works fine but the Xbox series x comes up with the content couldn’t be displayed message. Very annoying
Bengie11
See that is weird because I have the Xbox one x but mine doesn’t work lol
Erth
I had the same problem and couldn't multiview my Xbox and YouTube. It worked in the past, so I had to think about what I changed to make it stop working. I found that I turned my Xbox series x to a refresh rate of 120 hz. When I returned the Xbox display settings back to 60 hz, multi-view works again!
dNak08
Thanks.
RealFord89
Thank you! I was getting so frustrated with this issue. Switching back to 60hz on my Series X worked!
KelvinRonaldo
It's the frame rate. If you set the Xbox to 60Hz it works
