04-12-2024 10:35 AM
I want to be able to manage my Q800b soundbar via an App
I have Samsung app on my phone (pic of icon below) it connects and I can use it as TV remote ... so it is working.
I read here that I can add the Q800b to the SmartThings app ..... (press +) but no such option on my App.
How do I manage the Q800 ?
Solved! Go to Solution.
10-12-2024 11:12 AM - last edited 10-12-2024 11:53 AM
Update -
My problem was the Q800B soundbar was not accessible via the App ......it showed it, but when following instructions I could not add it. (Automatic registration & manual)
I spent some time on-line with Samsung support, and eventually, they gave a sequence to rest the Q800B
This is different to a power cycle ...
Steps are - With the Soundbar on, press the (- and +Volume) buttons on the body at the same time for at least 5 seconds. “INIT” appears on the display and then the Soundbar is initialized. It shuts down, you then reboot
Once I did this it automatically appeared on the phone and I could complete the setup.
Put the details above in case it helps someone else.
04-12-2024 12:43 PM
04-12-2024 08:13 PM - last edited 04-12-2024 08:14 PM
This is the problem part …. It states:
04-12-2024 08:14 PM
10-12-2024 11:11 AM
yes didn't work
Update -
