I can't figure out how to open two different apps in multi-view, like Netflix and Hbo on 65q60c
(Topic created on: 20-09-2023 06:48 AM)
Vladd1
I can't figure out how to open two different apps in multi-view, like Netflix and Hbo. I only get options to split between live tv and computer or phone mirror or camera.
8 REPLIES 8
helper-K
Navigator
Tap the icon on the recent tab then press split screen them chose the app hope this helps bye!
Vladd1
Thank you for your reply but please be more specific, I don't understand your answer.
helper-K
Navigator
So when you press on the the lines button on the bottom of your screen that will open up the recent tan menu then click the icon of the app you want to split screen it is located above the tab then press split screen app and scroll down the list and find the other app you want to open in split screen with the other app must require One UI 5 or later
Hope this helps 😁 in more detail I will alaso attach pictures Screenshot_20230921_151855_One UI Home.jpgScreenshot_20230921_151951_One UI Home.jpg
Vladd1
Oh, I am asking about the 65Q60c, the samsung TV with tizen interface. See the screenshots, I only get the option to add a mobile, computer or camera in the split screen.
WhatsApp Image 2023-09-21 at 17.44.26.jpegWhatsApp Image 2023-09-21 at 17.44.27.jpeg
helper-K
Navigator
Ohhh soory try the add your own many if not I'll do a bit of research
helper-K
Navigator
Get to you soon
Vladd1
No, adding my own is not helping at all.
I tried to research bu couldn't find anything relevant.
helper-K
Navigator
Ohh soory I could not find any thing to soory 😔
