01-03-2023 02:21 PM
Hi,
I have a Samsung Q70 series. Through my job i have the need to see what resolution and colour space (HDR/SDR) the different built in apps are playing on the TV.
Need the same information as you get on the top right of the screen when you select a connected device - for instance the AppleTV. See attached screenshot.
Hope there is a way.
GeirK
