29-12-2020 06:40 PM
I currently have a Samsung UE55KS8000 tv which is mounted on a stone wall. The mount I have is not height adjustable and the bottom of the tv is located just above a wooden beam which also can’t move. I want to replace the tv with one which handles Dolby Atmos but I need to use the same mount in the same location as it is very difficult to move.
Do any of the new Samsung 55 inch TVs have the vesa mount holes at the same height so it will fit on the same mount in the same location?
