Heavy red tint all of a sudden
(Topic created on: 03-12-2024 10:45 PM)
Ryanhogie
Hello, I have a couple year old Samsung smart tv from Sam’s club and all of a sudden today when I turned it on, all of the sources (so not just an hdmi cord) have a very heavy red tint. Red tint as in like that’s the only color that’s showing up. Just red and black. Am I going to have to return the tv to Sam’s club or is there an easy fix?
2 REPLIES 2
JAMES4578
Samsung Members Star ★★
Hi @Ryanhogie  I see that Sam's Club  is a membership warehouse club in the US,   we are the  UK/Ireland/European communities though.   Not sure which kind of warranty you have.   This can be caused by a varietry of factors such as  firmware glitches, HDMI connection problems, or hardware failures like panel defects or power supply issue . check you have the latest update and that connections are secure. If you take a Picture Test, Settings-Support-Device care-Self Diagnosis are errors highlighted ?
Simple123456789
Easiest answer is to reset TV but you could reset picture settings and retry that first, normally these days its not a serious issue. Goodluck
