ERROR_MODEL_BIND issue. even after connecting to internet
(Topic created on: 19-08-2022 08:07 PM)
sulagna
Hello Team
I am getting the below issue while connecting to internet. The network setting says internet is connected but when i am trying to use the web, it gives error. Please find the attachments
2 REPLIES 2
catwoman143
I think it might be the connection, or the broadband you have. You should try leaving it off for a few days then turning it back on. I hope this works🤞🤞
JAMES4578
Samsung Members Star ★★★
Hi @sulagna You do name your model firstly can you check that you have the latest firmware.   you can check your model  on Samsung support via the search barhttps://www.samsung.com/uk/support
If you have the latest update or that does not help a few steps you can try
A Smart  Hub Reset https://www.samsung.com/au/support/tv-audio-video/reset-smart-hub/
A soft Reset (Menu -Support - Self Diagnosis - Reset)
Reset Router by unplugging from the Mains for a few minutes and then connecting again.
Changing  the DNS Servers (Menu -Network -Network Settings - IP Settings - DNS settings - Enter Manually.   At this stage input  8.8.8.8 or 8.8.4.4.  followed by save.
