Go to solution Solved
error code 0-1 shows when trying to connect to smart hub
(Topic created on: 08-01-2017 02:38 PM)
hornet
Hi Just purchased a UEk5500 connected to wireless hub ok but keep getting error code 0-1 at step 2 (terms and conditions) screen. Any ideas?
Go to solution
23 REPLIES 23
Sam72
Thanks Mox. Tried that but, getting error code 102 now.
Nickolinio
Go network / network status / ip setting / DNS setting change to manually and enter DNS server 8.8.8.8
Africa2
Make sure you are signed in through your Samsung account. Your internet  connection  should be strong.
JCruz
Hi, go to Samsung's website on a computer and download  update 1209.2
Then transfer to a USB and make sure to unzip the file. Plug the USB into your TV and go to Support and click on update now and follow the instructions on screen. It will fix the problem
mustafa85
I have the same issue , how can I solve it?
Bloodnite
"Go network / network status / ip setting / DNS setting change to manually and enter DNS server 8.8.8.8"
This worked. Thanks a ton.
Nicole28
I was having the same problem with my TV. All I did was reset it and it let me get past it.
Renzema
I did have the same problem. I did fix the problem to reconnect my Tv from cable internet to wireless. Strange but it was fixt.
nitesurfer
Just solve it now by first reseting to factory . on smart hub configuration, after the term and greement error : 0, push, forward(>>), 2,8,9,rewind (<<),in sequence, wait for a while then when geo location select the upper most section ( this is how i set current location because Brunei is not available in the  selection) you can try your current location if available. got this through searching the web. and it work for me.
RKShukla
Pioneer
I fixed the error on my TV by following this tutorial:
https://technastic.com/samsung-smart-tv-error-codes/
