easy connect to pc not connecting to wired ethernet
(Topic created on: 05-05-2023 03:26 PM)
xanderbenz
Hi,
Im trying to connect my pc with my samsung TV, but it says that my pc isn't on the wifi. My pc is connect via a ethernet cable that's plugged into the modem. Anyway to solve this? i want to look Crunchyroll on my tv lol
7 REPLIES 7
Pugs1957
SuperStar
Just turn on wifi on your router should do the job. I have the same set up.
xanderbenz
Like only turn of the wifi? i did a hard reset on my router, but its still isn't working
Pugs1957
SuperStar
No, turn wifi on or connect TV to router via ethernet.
xanderbenz
so the problem is, can only do one of the two, connect with wi-fi or cable?
Pugs1957
SuperStar
Correct, you can't mix and match connections.
xanderbenz
no i want to watch crunchyroll, but it isn't supported by samsung since the dont use andriod
xanderbenz
