11-08-2019 04:14 AM
I have an issue with my TV having different Diseqc numbers programmed for satellites than my dish positioner. I use a seperate reciever for specialist feed channels which uses the same numbers as my positioner. My TV thinks Astra is Hotbird, and Hotbird is Astra (19.2) and the other satellites have the 'wrong' numbers configured in the TV. I've used some channel editing software to analyse the channel configurations, but the numbering for the satellites is wrong.
Can anyone help with the Diseqc numbers assigned to satellites in this tv? I'm only interested in 30 degrees W to 30 degrees E. I've asked Samsung but the 24 hour response has not happened. I'm guessing this is a hard question to answer.
