20-04-2020 07:22 AM in
TVHi,
I just bought one of new QLED TV's and I've been playing around with the ambient mode on it. I managed to take a photo and send it to the TV but I really don't like it. So I wanted to delete the custom photo as it keeps popping up as default when I go into ambient mode. I've searched everywhere for instructions on how to delete the custom photo but I can't find an exact answer! Has anyone worked this out or is the option to delete just not available?
20-04-2020 09:55 PM in
TVI am having the same issue with my Q70T. The picture is horrible but I can't delete it.
21-04-2020 01:57 PM in
TV
It looks like there isn't an option to delete. Really annoying! When I took a photo using smart things it took the bottom of a picture above my TV and put it onto the ambient screen 3 times. Looked awful! However last night I re-took a photo and this time it just matched the painted wall. So at least I have a reasonable background now. Silly that they can't be deleted though! I find the Ambient Mode glitchy.
03-06-2020 02:25 PM in
TVHI!
I'm not able to delete photo in Ambient background Theme in my Qled Q80R.
Please reply me how to delete it.
26-06-2020 02:40 AM in
TVHaving the same problem. Took a picture and I have too much stuff around my tv to look good in the photo. Would like to just reset or remove this photo but don't see an option to do so (only to retake which I don't want). Any advice would be great!
01-07-2020 01:03 AM in
TVYou've probably worked this out, but, for those who are having the same problem with a new Samsung Smart TV, one workaround is simply resetting your TV to factory settings: SETTINGS>GENERAL>RESET. You'll have to type all your info back in, but at least you get a second chance to play with the Ambient feature.
01-07-2020 02:03 AM in
TV
Not to mention log into all the apps, put settings back etc etc. Boggles my mind how many things need a factory reset for something simple. It's like phones when they say, "Just factory reset it." Then the 2-3 hours after putting everything back, logging in, setting up security/fingerprints to find it's not fixed the actual problem lol.
01-07-2020 03:50 AM in
TVThanks so much! I figured that was the last option and out of pure inconvenience I've avoided it so far. It's mind blowing that such a simple step isn't even an option. : / Hopefully they fix this soon!
01-07-2020 03:52 AM in
TVTotally! Plus the thought of screwing up another ambient picture upload and having to do it all over another time. So impractical! Please fix Samsung!
01-07-2020 10:48 AM in
TVI presume this is an issue with not being happy with the background photo.
The multiple photos showing the ceiling is an issue Samsung need to sort out!!!
To change the photo, and give you more options than just taking a photo of the whole TV, go to:
Special Edition Porcelain Hours and press STYLE & SETTINGS
You will now have the extra "BASIC" option to take photos of just one side of the TV. This means you can choose the side with the best free space to get a better background.
It should also give you an option to "smudge" the resulting images to remove any solid images that you don't want on the background. (maybe a light switch).
This should now be your default background for all moods/decors.
