AU7100 feet too wide apart
(Topic created on: 16-04-2022 03:20 PM)
Jimbi21
I've been looking at buying a new TV and the 50" AU7100 looks good, however the feet are too wide apart to fit on my table. Is there any way around this excluding wall mounting the TV?
3 REPLIES 3
LeoXXL
Navigator
Buy another table that fits your TV, or fix it on the wall.
Ginga_p
Troubleshooter
You can buy tv legs from amazon that screw into the wall bracket screws on the back of the tv this might help
G G
antikythera
Black Belt
Depending on the table surface, get some matching wood or toughened glass wide enough for the new TV? It will be safe because the load would be spread across the table that way
