Sound assistant module needs fixing
(Topic created on: 20-12-2024 11:58 AM)
purplebottle
Currently when using good lock to customise the volume slider position and expanded menu, it appears in the old style rather than the oneui 7, itd be much better if it has the new oneui 7 appearance. Ill also give this is beta feedback.
1 REPLY 1
AnnaMaz
Beta Moderator
Beta Moderator
Hello @purplebottle,
Thank you for reporting! The developer team is doing their best to update all Good Lock apps so that they would be compatible with One UI 7 as fast as possible
Have a good day!
