Bug Detected using Power Saving Mode [Maximum]
(Topic created on: 2 weeks ago)
SantosUK
System shows not understand the operator order and mix normal battery use with power saving.
@samsung
2 REPLIES 2
Clive7409
Voyager
If a bug be sure to report via the feedback button for the beta. Samsung Devs don't generally monitor the chat.
MartynaK
Beta Moderator
Beta Moderator
@SantosUK
It sounds like a possible issue with how battery usage stats and power saving states are being calculated or displayed together in the current beta build.
If normal usage and power saving data are being mixed incorrectly, this is likely a system-level bug rather than user settings.
Please report it via the Samsung Members so it can be reviewed with logs.
