TV and monitor react to same remote
(Topic created on: 22-04-2023 05:26 PM)
Roostan
In my living room I have a TV (Samsung QE50Q60AAU) and my recently bought monitor (Samsung Odyssey G7 LS28BG700) and they both react to eachothers remotes... This is extremely annoying... Help! (They are both connected to internet with ethernet cable)
5 REPLIES 5
Daniel-M
Helping Hand
Hi!
Unfortunately there is no fix for this. Both controls send IR signals, which both the TV and your monitor will react to the remote when you press a button. What you can do is move them further apart or try to direct the control further away from the screen you don't want to control.
We hope this is of some help.
/Daniel
GG1993
I’ll probably just return my monitor due to this design flaw.
swany78
I set up my monitor yesterday and this morning it turned off when I turned my TV on.  The remote that came with the monitor is apparently connected by bluetooth and controls only the monitor, so I am just going to tape over the IR sensor on the monitor.
Tesla1
i have the same setup. A QN800A TV and Odyssey G8 monitor  both on my living room. When i turn on the tv the monitor turns on as well. But if you cover the front of the remote of your TV with your index finger tightly and point it to the TV only the Tv will turn on and not the monitor. It worked for me.
Tesla1
