Batery drain- Bright screen and Constant vivid mode
(Topic created on: 23-10-2019 03:53 PM)
Justryan94
Hi all,
So over the past 2 day's of using the beta I have noticed that my phone screen is constantly brighter than before (regardless of the level I set it at) it seems like video enhancer is on all of the time, with super bright whites and colours.
And to add to this whilst I have display mode on neutral it doesn't change. Switching between that and vivid makes no difference.
Both of these are draining my batter much faster than before.
Ryan
2 REPLIES 2
TomaszT
Beta Moderator
Beta Moderator
Hi @Justryan94
Do you have adaptive brightness enabled? It might be the root of the problem, so it is worth trying to turn it on/off.
Also make sure to send us an error report via Beta Feedback option in Samsung Members app, so our development team can analyze the problem in detail and possibly find the source of the issue! :hand-with-index-and-middle-fingers-crossed:
Justryan94
Adaptive brightness is turned off. Its said the phone is using higher nits of brightness at every level on the brightness bar.
I'll be sure to send a error report
