Why apks installed doesn't work
(Topic created on: 29-10-2023 03:49 PM)
AmirMhmd
Voyager
I have noticed that apks that has been installed from outside the play store or galaxy store does not work
Apks downloaded from the Web
Tags (3)
6 REPLIES 6
NinjaRanga
Voyager
Check your security settings as these may have been reset when you installed the beta: Settings > Security and privacy > More security settings > Install unknown apps and then select the source of the app to allow it to install.
UNKNOWNUSERNAME
Samsung Members Star ★★
following the comment above, make sure auto blocker is disabled.
MPNI2025
AmirMhmd
Voyager
The problem is , the app installs fine but when i attempt to open it, it closes straight away
AmirMhmd
Voyager
The auto blocker is disabled
AmirMhmd
Voyager
And i have tested the same apk app on android 10 samsung s21 ultra and it works fine and also it was working fine on my s22 ultra android 10 one ui 5.1
AnnaMaz
Beta Moderator
Beta Moderator
Hello @AmirMhmd,
It is possible that the apps that you are trying to open are not compatible with One UI 6.
Have a good day!
