Phone Overheating
(Topic created on: 30-07-2025 07:11 PM)
Cliffordcov
Is anyone else having the same overheating issue where your s25 ultra gets extreamly hot to the touch
3 Solutions
arianwen27
Samsung Members Star ★
Good guardians, thermal guardian. Might help spot what's causing it.
weskerevil
Helping Hand
Nothing on mine 👍
AnnaMaz
Beta Moderator
Beta Moderator
Hello @Cliffordcov,
Thank you for reporting! Please also consider registering feedback via the Samsung Members app and attaching log files for further assistance. It would help greatly in identifying the issue
3 REPLIES 3
arianwen27
weskerevil
Helping Hand
Nothing on mine 👍
AnnaMaz
Beta Moderator
Beta Moderator
Hello @Cliffordcov,
