How to add custom notification sound on One UI 8?
(Topic created on: 13-08-2025 02:12 PM)
Aldreno
Navigator
Im having trouble figuring out how to change the notificstion sound to a custom one. For One UI 7, it was very easy, just move the custom notification to the notifications folder and it would show up in settings. However with this new One UI 8 beta update for S24 (Beta 1, 13/08), there is no notifications folder visible.
Any help is appreaciated.
2 REPLIES 2
MartynaK
Beta Moderator
Beta Moderator
Hi @Aldreno,
It seems you're having trouble setting a custom notification sound in the One UI 8 Beta on your S24. While the process has slightly changed compared to One UI 7, here’s what you can try:
  1. Move your custom sound file (e.g., .mp3 or .ogg) into the Notifications folder in internal storage. If the folder isn’t visible, you can create one manually.
  2. Go to Settings > Sounds and vibration > Notification sound.
  3. If the file is in the correct format and location, it should appear in the list.
If you're still unable to select the sound, I recommend submitting feedback via the “Beta Feedback” section in the Samsung Members app, along with log files. This will help our development team take a closer look. Thanks for your input! 😊
medhora
Having the same issue! Why does Samsung have to change things and complicate further for the users.
