Fast charging not working?
(Topic created on: 22-09-2022 07:50 AM)
hmptec
Pioneer
I'm using an official Samsung charger but fast charging is not working for me. Anyone else? Thanks
3 REPLIES 3
theoracle
Pathfinder
Hi, fast and super fast charging are working ok for me. I have experienced the issue before but that is usually because of a bit of dirt or fluff in the charging port. Also check you have it enabled it the settings.
hmptec
Pioneer
It's ok now. Thanks very much
AnnaMaz
Beta Moderator
Beta Moderator
Hello @hmptec,
As I understand this issue is already solved (thanks @theoracle!), but if you encounter any errors always feel free to report them via the Samsung Members app 😊
Have a good day!
