Edge notification options
(Topic created on: 16-03-2025 04:48 PM)
matthewk421
What happened to all the other options for edge notifications? There used to be more options (I think the one i used before was 'Wave') but they've all disappeared in the One UI7 beta. Will they come back for the official release?
2 REPLIES 2
Fiona26
Samsung Members Star ★★
Edge lightning + in the good lock app gives you some more options. It's available in the galaxy store.
AgnieszkaMP
Beta Moderator
Beta Moderator
Hello @matthewk421 !
Did you find the tip from @Fiona26 helpful?
Have a great day! 😊
