Go to solution Solved
Do not disturb mode across all device
(Topic created on: 03-11-2021 08:50 AM)
NewAge
Navigator
This is something really bad.
When I put my Galaxy watch 4 on DND mode it activates it on my phone too.
My Galaxy ultra also goes on do not disturb mode. I checked on vibration and on sound, but as soon as I put my watch on DND mode it activates the same on phone too.
Big bug
Needs fixing ASAP.
Has anyone else noticed anything like this?
2 Solutions
KirkyLAD
Pathfinder
It's a feature and can be turned off in the Galaxy Wearable app
Watch setting > Notifications > sync do not disturb on phone
MartynaK
Beta Moderator
Beta Moderator
@NewAge,
I am glad to hear the problem no longer bothers you 😊@KirkyLAD, thanks for your help!
3 REPLIES 3
KirkyLAD
Pathfinder
NewAge
Navigator
Thank you.
I didn't turn ON this feature and it started to behave this way so I was so confused thay why its doing this.
Perfect
Now sorted.
Thank u
MartynaK
Beta Moderator
Beta Moderator
@NewAge,
