Bluetooth issues
(Topic created on: 01-11-2022 05:28 PM)
Dapp
Pathfinder
I'm using a  Galaxy S22 Ultra. Before the one UI 5 beta the Bluetooth audio used to skip and whilst on the beta, this problem disappeared. Now on the official one UI 5 version and the problem is back. Has anyone else had issues like this?
1 REPLY 1
MagdalenaPo
Beta Moderator
Beta Moderator
Hello @Dapp,
I must admit that I had not heard of this problem before. Perhaps some backlogged files from the previous version are causing this problem. 🤔
In this case, you can try to 'wipe cache partition' through the Recovery mode:
  1. Turn off your device
  2. Connect your device to the PC via USB (not to the charger)
  3. Wait until the message that the device is being charged appears
  4. Press and hold down the volume up and then power buttons and hold them until the device turns on
  5. Recovery menu should appear
  6. from there select "Wipe cache partition" (you can navigate using volume up/down buttons and confirm with a power button).
