Battery saving mode and adaptive display 120 Hz sm
(Topic created on: 08-10-2021 05:01 PM)
pmel
Pathfinder
Hi, do you know how to turn on battery saving mode and adaptive display 120Hz the same time? I used trick in Android 11,but now doesn't work. Thanks for help.
5 REPLIES 5
adamlee
Big Cheese
Yeah looks like they patched it with android 12, I think they should add an option here to keep 120hz in power saving mode. A lot of people would like that option. Screenshot_20211008-181041_Device care.jpg
pmel
Pathfinder
Yes, it's very helpful for battery and I hope they will add it.
DaveS1000RR
Very odd, mine still works, I have the exynos Ultra in the UK. As you can see it is 120HZ and medium power saving. When I downloaded the beta it transferred over from 3.1Screenshot_20211011-082737_One UI Home.jpg
MartynaK
Beta Moderator
Beta Moderator
@pmel,
I'll suggest our developers that it would be convenient to have the option to turn on Battery Saving Mode and Adaptive Display 120hz at the same time. Let's keep our fingers crossed so that the option can be introduced! 😉
Russ82
Yeah I always had this option enabled constantly on android 11
