02-03-2026 04:05 PM
02-03-2026 04:28 PM
No it definitely an error, according to EU Battery endurance stats the S25 series was rated for 2000 cycles , subsequently would drop to 80%. Higher than S26 Series though. https://www.phonearena.com/news/all-three-galaxy-s26-devices-may-get-a-shocking-battery-downgrade_id...
02-03-2026 04:38 PM
02-03-2026 06:30 PM
02-03-2026 11:05 PM
03-03-2026 11:46 AM
03-03-2026 01:15 PM
03-03-2026 01:30 PM
Hello @busby08,
That's certainly an impressive number 😶 What usually happens is that a software glitch or a mis‑read from the battery‑stats service reports an inflated value. The reading itself isn’t harmful, but it can be confusing.
You can try to restart the phone - a simple reboot often clears temporary stats errors. If the number remains absurdly high, consider filing a bug report via the Samsung Members app so the engineering team can investigate further.
Have a good day! ☀️
05-03-2026 08:36 AM
05-03-2026 10:07 AM
