Android Auto issues ?
(Topic created on: 06-02-2026 07:23 PM)
kkreddy
Anyone facing Android auto issue? Android auto is not working for me.
4 REPLIES 4
WhatIsLife
Helping Hand
Working fine for me, even working fine with wireless android auto. What is the actual issue your having?
MishXt
I've had this issue for time. I use wired connection and at times when I connect it doesn't connect it and shows my phone just charging and then unplugged. Does that for some time. Then when it does connect after many attempts, audio may not work so I have to reinsert cable. Other times I have to start my car again for auto to work. Ongoing offshore which i have raised and shows that they are looking into it
kkreddy
After plug in cable, it says connecting then disappears. Car it wont start or show anything .
MartynaK
Beta Moderator
Beta Moderator
@kkreddy,
Please submit this issue through the Samsung Members app, including any relevant details, so that the development team can investigate :hand-with-index-and-middle-fingers-crossed:.
