Sluiten
annuleren
Resultaten voor
Zoek in plaats daarvan naar
Bedoelde u:
Oorspronkelijke onderwerp:
Samsung S8 does not connect to Gear VR or USB-C powerbank
(Onderwerp aangemaakt op: 16-10-2017 02:22 PM)
232 Weergaven
The_Rutger
Opties
My first batch Samsung S8 (apr. 2017) had no issues connecting to my Gear VR with Controller, never missed a beat.
Ever since my holiday last week to Vietnam it does not recognize the gear VR when I plug it in.
My friend's samsung S8 (Relatively new) does work immediately when it is plugged into the Gear VR.
The next test I performed is with the Anker Powercore 20100+ Powerbank which has 3 outlets. 2x Ordinairy USB and 1x Usb-C.
The normal USB to USB-C works as supposed to but the USB-C to USB-C charging does not work.
Again, it works on my friend's S8 without a problem.
I have performed a Cache wipe and Factory reset, both without any changes in behaviour.
I suspect the humidity of Vietnam has affected the USB-C port, as I used to get a lot of "Moisure Detected in Charging Port" notifications during my holiday. Is there a fix?
1 Antwoord
Rohit
Samsung Members Star ★★
Opties
I think that the best thing you can do is to go back to the store or let Samsung pickup your Phone.
Backup and reset:
http://smsng.nl/resetmobfbwc
Pick up: service: http://www.samsung.com/nl/support/selfservice/#ophaalservice
Good Luck!
Stars-Moderator-signature-800x200-2
