20-10-2023 04:28 PM
F34 Heating and battery draining issue need some update to fix it as soon as possible
21-10-2023 05:24 AM
Have a look in your Battery settings to see if an app has gone rogue etc @Kaushik_Haz
There you can tap on the optimisation button too.
Also try >
Clear Cache Files from the phone's System Partition Section > https://www.samsung.com/uk/support/mobile-devices/how-do-i-clear-the-cache-on-my-device/ You may need to insert your earphones or hook upto a powered On Laptop or use a Tv's USB Port to access the Clear Partition Section. This may help with lag or stutters as this clears the phone of old/unused or broken cache files.There is also a Repair Apps option in the Menu System too.
You can send any feedback via your Samsung Members App too.
If I can be of any further help then please don't hesitate. Take care. 😎
Daily Driver > Samsung Galaxy s²⁴ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
