Call sound issues - others can't hear me during calls
(Topic created on: 25-03-2021 11:18 AM)
Nicci86
Hi there,
Ever since I got my Samsung Galaxy S21 I have an issue where when either making or receiving calls I can hear the other person but they can't hear me.
Initially I thought it might be a signal problem but it happens wherever I am, I have even turned on wifi calling to get around signal issues.
If I call via whatsapp or facebook messenger then it is totally fine so its not a problem with the microphone. It happens whether i'm using the phone as normal or with earbuds.
In addition sometimes when someone calls I press the button to answer the call and it says it has answered but the phone is still ringing so the call isn't actually connected.
It feels like it is an issue with the phone and not my signal as with old phone (S10) it was fine in the same areas and no issue.
Any ideas on how to fix it?
118 REPLIES 118
BeckyJ1
Mine is exactly the same. Just wish Samsung would investigate and fix
BillyBoo81
Hi, I am having similar issues too, what can I do?
Chris2460
I did a factory reset on the phone but still had the same issue's.
So proceeded to do this  On the main screen tap the green phone icon/  then the 3 dots top right / Settings / click on caller I'd and spam protection /     Make sure caller I'd and spam protection is turned off,   and also Turn off Block Spam and Calls . Reboot phone . I have not had a problem since,
So I am Wondering if the factory reset is part of  the key to fixing the problem, as I see many of you have tried the above  and still have this problem.
It has been over 2 weeks since I did this and not had any problems.
queenys
This issue literally just started for me out of the blue,  and turning off wi-fi calling resolved it.   Thank you!
JAW008
I bought mine 2 months ago and I have the same issue (others cannot hear me).
If this is not fixed by the time my contract is over, I will move on to another phone. I like the phone for the camera capability, etc but its primary use is for calls. I would also want to stick with android but am not sure who (besides Samsung) makes the best phone. Any suggestions would be welcome.
Gsv75
My wife has exactly same issue, when calling over normal phone app - there's no incoming or outgoing sound.
Temporary solution is to restart the phone and then it works, but it goes wrong after some time. Did this restart 3 times in the last 3 days.
For the first few months there was no issue though, so not sure where's it coming from, but certainly samsung should do more to support
kiyani
I have been having the same issue with s21 ultra since new . Samsung have tried to change settings and do various things over the phone to no avail. They asked me to send it in for repair under guarantee and have supposedly replaced various bits. The problem is still there. I am hoping to send it back ASAP after speaking to the. Tomorrow. This has to be a design fault either in soft or hardware. Really frustrating and shouldn't happen to a top of the range phone. Samsung must know about this and should recall these sets and refund people.
Khalid.
Choppercox
My girlfriend had same problem with her phone on 3 network 2 new phones later I put my virgin SIM in her phone and the problem was gone. So called 3 and had a new SIM sent out and now it works fine they said the SIM she was using was 5 years old so not up to date with 5g etc. So I would advise trying a different SIM before trying anything else.
Members_FUim4wK
I'm doing what you said to do as I'm sick of people not hearing me, but I can hear them..It doesn't happen if they ring me..Is it still working for you disabling this VoLTE calls sim 1..?
Pipster
I have the same problem, I can hear Callers but they can't hear me. Very annoying for a new phone
