Sluiten
annuleren
Resultaten voor
Zoek in plaats daarvan naar
Bedoelde u:
Oorspronkelijke onderwerp:
Problem with koelkast Model RB37J5925SS
(Onderwerp aangemaakt op: 16-06-2019 09:45 PM)
225 Weergaven
Ioana2019
Opties
Dear all,
I bought a Samsung koelkast Model RB37J5925SS 2 days ago but I noticed the noise it makes and how long the noise takes. I've read the instructions but it doesn't say if there's any button to make it silent. Also, if we open the door or introduce products in the fridge/freezer, it starts the ventilation (or what I assume it's the ventilation) and it takes a very very very long time until it stops. I'm very concerned about the electricity it spends and also the noise level. This is not the first koelkast I have and but it's really the only one that makes so much noise. The fridge is set to 3 degrees C and the freezer to -19 degrees C.
Does anyone know if there's any function to make it work silently? OR at least know a solution for it?
Many thanks in advance!
Kind regards,
Ioana
1 Antwoord
Tim
GrandMaster
Opties
Hi Ioana, that's very unfortunate to hear 😞 I would like to tell you more about the sound your refrigerator is making. Do you have a video of the sound your refrigerator is making?
Moderator-signatures-v1-NL You must take your place in the Circle of Life." ~ The Lion King
