Fermer
annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Sujet d’origine :
battery problem
(Sujet créé le : 05-12-2024 04:50 PM)
223 Visites
SoryuAsuka
Navigator
recently, for this new S24FE after only less than 2 months of use , I find its battery drop too quikly when under 5%. normally using, a 80% can last less than 6h (I only charge it to 80%), so 5% should last about 22min, however it's last 5% lasts only 3 or 5min now, drops too quikly. soit it has a broken battery management, soit it has wrong detection of the true percentage.
0 Compliments
4 Réponses
Alyer
Voyager
Hello, that's normal ig because every battery are not very well calibrated on Android, I mean battery level is never linear on a phone device, it happen for iOS, android, windows phone, and pretty much all devices that run a li-ion/li-po battery
AkachibyJ
Hello @SoryuAsuka,
Thank you for your message.
To ensure that all members of our community can understand and assist, we kindly ask you to post your messages in French. This will help us better assist you and ensure that everyone can participate in the discussion.
Thank you for your understanding!
0 Compliments
SoryuAsuka
Navigator
I know, however I'm not satisfied with the fact that the phone was more durable when under 5% than it is now. This doesn't sound to be a unsolvable software problem.
0 Compliments
SoryuAsuka
Navigator
This is to protest against somebody's rudeness. d'ailleurs, DO NOT set yourself's reply as "accepted as solution" without my consentement. I saved evidence and canceled it, don't you do it ever again!
0 Compliments
