07-03-2019 09:43 PM in
Galaxy S9 SeriesHi suddenly my call volume is very low and can hardly hear the other person. Works fine on bluetooth.
Solved! Go to Solution.
04-08-2020 06:20 PM in
Galaxy S9 SeriesThank you !!!
23-09-2020 01:35 AM in
Galaxy S9 SeriesI started having this problem 9 months ago. I found this solution and I assumed I could just use an electronics wet wipe to clean the speaker. Didn't work. 9 months later I found this again and tried a toothbrush.
I can't believe I wasted the last 9 months asking people to repeat themselves because I didn't try a toothbrush! It's amazing now! The toothbrush worked!
So don't try to shortcut this solution.
03-10-2020 03:31 PM in
Galaxy S9 SeriesToothbrush metode worked for me THANKS FRIENDS
05-10-2020 09:45 PM in
Galaxy S9 SeriesI was about to pay a bundle to have my 9+ rebuilt to have the ear speaker replaced. A final google got me here and after a gentle brushing and blow away of invisible debris, boom: A NEW PHONE!! It all works great again. Amazing what a little pocket lint can do!!
17-10-2020 12:32 AM - last edited 17-10-2020 12:32 AM ) in
Galaxy S9 Series13-12-2020 03:40 AM in
Galaxy S9 SeriesThis worked perfect!!! Alcohol on a toothbrush and and alcohol wipe over the ear piece and the entire phone fixed it!!!! Thank you!!!
07-03-2021 09:50 PM in
Galaxy S9 SeriesWorked wonders on a 3 y/o S9 plus! Thanks a lot
09-03-2021 12:27 PM in
Galaxy S9 SeriesThanks for your help, I just used toothbrush and it worked.
21-07-2021 12:29 PM in
Galaxy S9 SeriesI couldn't get the toothbrush, wet or with alcohol, to work, but used a fine pin to gently clean the mesh over the speaker, that worked a treat!
03-08-2021 07:24 AM in
Galaxy S9 SeriesWow thanks for that advice, I was going to take it to a shop but the toothbrush worked so well I've had to turn the volume down to half way to avoid being deafened lol
