S9+ call volume low
(Topic created on: 07-03-2019 09:43 PM)
Sue78
Galaxy S9 Series
Hi suddenly my call volume is very low and can hardly hear the other person. Works fine on bluetooth.
Go to solution
63 REPLIES 63
Cmcnam
Galaxy S9 Series
Mine had the same issue of very low in call volume and I just cleaned it with an old toothbrush and I just cant believe how the volume opened up, i do this now once a month
MSG2
Galaxy S9 Series
The link you put for the solution doesn't work
MSG2
Galaxy S9 Series
What is the 9s solution?
MSG2
Galaxy S9 Series
What speaker holes?
MSG2
Galaxy S9 Series
The link does not work. Can you please tell me the solution? Very frustrated.
Carolebryant
Galaxy S9 Series
The speakers above the screen are the ones that need cleaning with a soft toothbrush
Zinny
Galaxy S9 Series
@Shadrachbeba wrote:
Mine had the same issue of very low incall volume and I just cleaned it with an old toothbrush and I just cant believe how the volume opened up.
Had same issue and used an old toothbrush, vola it worked.
sandralb
Galaxy S9 Series
The volume on my phone doesn't sound as loud as it used too
Sandy_0455
Galaxy S9 Series
Definatley worked!!!! Thanks alot!!!
Hergis
Galaxy S9 Series
you are a genius
