Samsung s23 ultra battery drain
(Topic created on: 26-04-2025 07:46 AM)
zoeangel
Anyone had a problem with battery drain over night...my phone is only a year old and since the march update its been draining...95% last night to wake up and its at 53% it took 2 houurs to charge it and that was on a fast charge..its a pain in the backside realy it is...never had problems with samsung befor and ive been with them years...debating wether or not to go with a different phone now
19 REPLIES 19
sarasphotobox
Big Cheese
Hi have you checked in battery under usage what apps are using the battery.
Have you enabled power saving mode
Also did you recently update you’re phone to One ui 7
This doesn’t sound right  8”95% to 53%
I hope it’s resolved
Piper123
Samsung Members Star ★
Hey there
Can you please run diagnostics on your device to see if the battery is reporting an issue?
S24 Ultra
zoeangel
It says system ui in the background for 7 hours and thats it
zoeangel
All fine with that one...
Piper123
OK so given your battery is dropping so much, must be an app or apps that are causing battery drain.....
Settings
Device Care
What is using up the most battery?
S24 Ultra
SC489
Navigator
My S25 overnight drain is c. 5% with a sleep routine which disables most stuff and apps in deep sleep. Turning off the SIM card reduces the drain to 3%.
zoeangel
System ui in the background...could it be the fact i turned my internet off last night and the system was looking for a connection
rileylovetech
Navigator
Have you got apps in background
sarasphotobox
Big Cheese
Oh wow really how do you turn off sim card what if you put on aeroplane mode
