S25 Overnight Battery Drain
(Topic created on: a month ago)
SC489
Navigator
I have a S25 256GB phone. I have a sleep routine to turn off most stuff overnight but the battery drain overnight is around 5%.Is this typical and are there any tips to reduce the drain?
6 REPLIES 6
Fiona26
Samsung Members Star ★
5% really isn't too bad. I set up some bedtime routines myself. Power saving mode on, location off, mobile data off. I also use sleep mode.
Overnight battery drain can be caused by several factors, including: active background apps, excessive syncing, Always-On Display being enabled, location services running in the background, outdated software, faulty apps with excessive permissions, and issues with network connectivity; all of which can continue to drain your battery even when your phone is supposedly asleep.
Check you network signal is good and check what you have syncing in the background.
SC489
Navigator
Thanks. I just put all apps in deep sleep except essential ones like messaging and phone. All connections WiFi, Bluetooth, mobile data, location etc. are off at night and mostly through the day unless needed. 5g is also disabled since there is no 5G signal where I live.
GoanGeek
I get around 5% drain without what you guys are doing.
Then again. I am an overnight charger. So not bothered. 😊
Follow Me, like my posts and Mark as Solution if I helped solve your Problems.
Joeeye
Legend
Typically 1%/h battery drain is considered good. Unless you sleep for less than 5 hours, I'd say 5% loss overnight isn't too bad.
SC489
Navigator
I've now reduced the overnight battery drain to 3% by deep sleeping many apps. However, there are a few system and Samsung apps I worked out nit to deep sleep by trail and error otherwise Samsung Backup will not work.
sarasphotobox
Big Cheese
I set routines but day time I have power saving mode
Also I set routines so when in a call data off etc
only sound on from specific callers
ljght profile on
standard refresh rate apps
AOD off
location off only set on for specific apps
