Edge Panel scrollable & 3-column layout not working in Home Up / good lock (One UI 7, all apps updated)
(Topic created on: 11-05-2025 08:19 AM)
I have this problem too
Mikiamoniko
Hi everyone,
I’m using a Galaxy S25 with One UI 7 and have the latest versions of Good Lock and Home Up installed. I noticed that in Home Up there’s a new feature related to the Edge Panel, which is supposed to make it scrollable and support a 3-column layout.
Unfortunately, this feature doesn’t seem to work at all. I've tried everything:
Cleared cache and data of Home Up
Uninstalled and reinstalled both Home Up and Good Lock
Made sure everything is fully updated
Still, the Edge Panel looks and behaves the same.
Has anyone else experienced this? Any ideas on how to fix it?
Thanks in advance!
1 REPLY 1
smiley
Samsung Members Star ★
It does work. But you need to add enough icons and then it increases the columns and makes room for three rows.
P.s. I just tried this as i wasn't aware of this function.
User: Smiley
If my reply has been useful in resolving your issues, then please like and 'mark as solution'.
My life is full of positives and negatives. I’m an electrical engineer.
