Edge Panel scrollable & 3-column layout not working in Home Up/good lock
(Argomento creato il giorno: 11-05-2025 11:52 AM)
80 Visualizzazioni
Mikiamoniko
Hi everyone,
I’m using a Galaxy S25 with One UI 7 and have the latest versions of Good Lock and Home Up installed. I noticed that in Home Up there’s a new feature related to the Edge Panel, which is supposed to make it scrollable and support a 3-column layout.
Unfortunately, this feature doesn’t seem to work at all. I've tried everything:
Cleared cache and data of Home Up
Uninstalled and reinstalled both Home Up and Good Lock
Made sure everything is fully updated
Still, the Edge Panel looks and behaves the same.
Has anyone else experienced this? Any ideas on how to fix it?
Thanks in advance!
5 Risposte
European Moderator
European Moderator
I welcome you to the official Samsung Italia Community. 😊
To use the function, you have to place the apps on the 3 columns. You can switch to the next one in fact, if the columns are full.
Good Lock>home up>Edge panel
The columns must all be full. (insert apps)
In any case, is your phone intended for the Italian market? Some functions may only be available in certain countries.
I can check by IMEI code, I suggest you contact me via private message and tell me this code.
Click here to send me a message: https://eu.community.samsung.com/t5/notes/composepage/note-to-user-id/61667460
I look forward to hearing from you. 🤝
Have a nice day
Jessica_A
Mikiamoniko
Hi Jessica, yes my phone is Italian but I have csc Tahiland.
I can't access to the link you provide me. Please help me to resolve
European Moderator
European Moderator
Hi Mikiamoniko,
after further checks, I see that the "Edge panel" section is not yet available on all products so it is definitely being improved.
Anyway, I have contacted you privately for some IMEI checks.
I await your response.🤝
Have a nice day,
Noemi_P
Mikiamoniko
Hi Noemi thank you for your support.
Just to be clear the edge panel on my phone is active, but there are no modifications with good lock module.
European Moderator
European Moderator
Hi @Mikiamoniko
thanks for this clarification.
I invite you to continue receiving assistance from Noemi in order to get precise information about the condition encountered. 🙂
Have a nice day!
Cornelia_L
