Go to solution Solved
Edge panel navigation gesture conflict and other edge feature requests
(Topic created on: 19-08-2024 09:10 AM)
ANR1
Pioneer
When gesture navigation control of swipe left or right from edge of screen is on it conflicts with the edge panel gesture and it's tricky to use edge panel swipe then. Can samsung disable screen navigation gesture in the area of edge bar so the conflict does not happen? Looking forward to the correction soon.
Also if you can allow any category of edge items to be merged into a single edge panel it would be great. Now we have to have multiple edge screens for different type of shortcuts. For example there is a different selection tool bar, and different edge screen to include screenshot etc. It would be great to have a truly custom edge panel with any shortcut to app, activity or homescreen item.
Thanks
2 Solutions
Glenntech
Samsung Members Star ★★★
You can download Samsung Goodlock app and get the Navstar plugin. You can customise the gestures.
The new swipe gestures is what Google has implemented to the Android software.
So to change the gestures, you will need Goodlock
ANR1
Pioneer
Edit: I found the 'one hand operation' module in goodlock which has solved my problem. Thanks for showing direction. Now I don't need edge panel as this module has gesture based shortcuts and zones
3 REPLIES 3
Glenntech
ANR1
Pioneer
Hi. Thanks for the suggestion. I tried it. However I could not find a side swipe gesture bar option to drag zones. I even tried the block zone options in one of the goodlock modules. Thanks for the help though
ANR1
Pioneer
